Kemable
Graph Builder Histogram Label Size
Hello!
Is there a way to change the size of the label on a histogram created in graph builder?  For example, with the "Little Pond" dataset, I created a histogram using column "Z" and then selected "percents".  I want to increase the size of the percents.  Circled below.
Re: Graph Builder Histogram Label Size
I'm not sure you can modify those from graph builder. Some font preference might control those, but I'm not sure
Scripting is also one option, but depending on how you want the labels to work, it might not that that simple script.
Kemable
Thanks for the reply!  I couldn't find the right preference to change that, but maybe I was looking in the wrong place.
Thank you!
SED
SED
For future seekers, histogram counts use the "Small" font in the menu shown above.
Level XIII
Hi @Kemable , @SED , you can use set Font() to adjust the font size:
dt = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
Graph Builder(
	Variables( X( :name ), Y( :height ) ),
	Elements(
		Bar(
			X,
			Y,
			Label( "Label by Value" ),
		Dispatch( {}, "Graph Builder", FrameBox,
			{DispatchSeg(	BarSeg( 1 ),	Set Font( "", 30, "", 0 )	)}
