SpannerHead
Eval Expr not working
Always confused by this one.  I created this formula based on one that worked previously.
// Get the current data table
dt = Current Data Table();
colNames = dt << get column names( continuous, string );
// Loop through all columns
For each( {col}, colNames,
Eval(
	Eval Expr(
		New Column(
			Expr( col ) || "_Gouge",
			Numeric,
			"Continuous",
			Format( "Best", 10 ),
			Formula( (Mean( As Column( Eval(col) ) [Index(1, 100)]) + Mean(As Column(Eval(col)) [Index(N Rows() - 99, N Rows())])) / 2 - Col Minimum(As Column(Eval(col)) ) )
Formula appears to remain unevaluated.
Slán
SpannerHead
mmarchandFSLR
Re: Eval Expr not working
As Column( Eval( col ) ) should be As Column( Expr( col ) );
mmarchandFSLR
SpannerHead
Finished thing looks like this.
Eval(
	Eval Expr(
		New Column(
			Numeric,
			"Continuous",
			Formula( (Mean( As Column( Expr( col ) ) [Index(1, 100)]) + Mean(As Column( Expr( col ) ) [Index(N Rows() - 99, N Rows())])) / 2 - Col Minimum(As Column( Expr( col )) ) )
Slán
SpannerHead
hogi
Level XIII
You could also use the below code. It will create column references which look as if the column was added in Formula Editor.
One of the benefits: when the input column is renamed, the formula still works.
Eval(
	Eval Expr(
		New Column(
			col || "_Gouge",
			Numeric,
			"Continuous",
			Formula( (Mean( Expr(Name Expr(As Column(  col ) )) [Index(1, 100)]) + Mean(Expr(Name Expr(As Column(  col ) )) [Index(N Rows() - 99, N Rows())])) / 2 - Col Minimum(Expr(Name Expr(As Column(  col )) )) )
