GroupSquareWolf
Getting the total row number
This is probably very simple, but I could not find my answer in Scripting Index.
Trying to write a script to return the total number of rows into a variable, eg, if a data table has 100 rows, return the number 100; if it has 50, return the number 50.
Using JMP16.
Thank you for your help!
Re: Getting the total row number
N Row() or N Rows() return this value for you. It returns the number of rows of the current data table by default. You can specify an argument that is a data table reference or a matrix and get specific data structure.
I recommend reading the Scripting Guide that is available in the JMP Help menu (documentation). There is also a browser for JSL through Help > Scripting Index.
GroupSquareWolf
Thank you!
