Hi @sanch1,
Welcome in the Community
There are a lot of questions that can help you focus on the design choice that may be best suited for your needs. In your case, having 2 factors and a 12 runs experimental budget may be sufficient to get the most of your data. A few questions to get you started :
- Preliminary knowledge : Have you already some knowledge about your experimental space and factors influences, possible response surface topology ? Have you already done previous experiments ? Do you think the optimal configuration could be at the centre of your experimental space ?
- Response variability & noise : Do you suspect noise could be an issue ? Have you information about measurement precision, resolution and accuracy ? Will the experiments measured only by one operator/equipment or several ?
- Objectives : What is your primary target ? Explore the experimental space, optimize, having a predictive model ? All ?
- Sequential/Fixed setting : Are you able to do sequential designs (to first assess possible interaction and curvature importance, and then optimize with perhaps a narrower factors ranges through a model-based or model-agnostic (Space-Filling) design) ? Or are you only able to do 1 design with 12 runs max ?
- DoE & Modeling experience : What is your experience with DoE and modeling ?
It's common good practice to test several designs, and compare the pros and cons of each through the Compare Designs Platform.
As for your question :
@sanch1 wrote:
The resulting DoE (full factorial, 1 replicate, 3 center points) seems good but under Fit Model, it says I'm not to estimate quadratic terms.
Centre points are used to estimate curvature, assess response at the centre of the experimental space, and may provide lack-of-fit test. Since they are at the centre of the experimental space (hence the name), you can only fit one quadratic term with it/them (out of the two possibles in your study : X1X1 and X2X2).
Regarding your interest in replicates, it would be important for your design choice/decision to know if you suspect some important variability in your system. You may be able to use repetitions and replicates simultaneously :
- Repetitions is about making multiple response measurements on the same experimental run (same sample without any resetting between measurements). It doesn't add independent runs, you just measure the response several times, to reduce the variation from the measurement system (by using the average of the repeated measurements).
- Replication is about making multiple independent randomized experimental runs (multiple samples with resetting between each runs) for each treatment combination. It reduces the total experimental variation (process + measurements) in order to provide an estimate for pure error and reduce the prediction error (with more accurate parameters estimates).
Depending on where you think the highest variability may be and your experimental possibilities, you may choose one or both of these techniques.
I hope this first discussion starter may help you,
Victor GUILLER
L'Oréal Data & Analytics
