Hi All, I need a formula to convert Calendar Date (column is in Character/Nominal Type, dd/mm/YYYY format) to Julian Date (numeric). For example, in Row#1 from 07-Mar-2024 (07/03/2024) to 24067:
Google search: 'calendar date to julian date formula'
The formula to convert a Gregorian date to a Julian date is: JD = 367K - (7(K + (M + 9)/12))/4 + (275M)/9 + I + 1721013.5 + UT/24. Where K is the year, M is the month, I is the day, and UT is the universal time in hours. The last two terms in the formula add up to zero for dates after 1900 February 28. [1]
M: Represents the month. January and February are treated as the 13th and 14th months of the previous year, respectively. For example, if the date is January 15, 2025, then M = 13 and K = 2024. If the date is February 20, 2025, then M = 14 and K = 2024.
