I want to plot multiple Variability plot with withe row legend display at the right. But when do this with the for loop, the row legend is not able to display. can anyone please advice?
the graph i intended to have for every parameters.
instead i only get the graph below with row legend display on the right.
dt = Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
/* Obtain a list of numeric/continuous column names as strings */
colList = dt << Get Column Names( Continuous, String );
For( i = 2, i <= Nitems( colList ), i++,
Variability Chart(
Y( colList[i] ),
X( :lot_id, :wafer ),
Connect Cell Means( 1 ),
Std Dev Chart( 0 ),
Dispatch(
"Variability Chart for " || colList[i],
OutlineBox,
{Set Title( "GROUP 1 Variability Chart for " || colList[i] )}
Dispatch(
{"Variability Chart for " || colList[i]},
"Variability Chart",
FrameBox,
{Row Legend(
lot_id,
Color( 1 ),
Color Theme( "JMP Default" ),
Marker( 1 ),
Marker Theme( "Standard" ),
Continuous Scale( 0 ),
Reverse Scale( 0 ),
Excluded Rows( 0 )
