Mattia
Fix unique scale for all parameters in parallel-coordinates
Hi all,
I would like to fix a unique scale range for all parameters in the parallel-coordinates (in graph builder).
Is this possible? If this is not possible in graph-builder, can I do it in the parallel-coordinates platform?
I ask this because the K-means clustering platform also uses the parallel-coordinates platform to visualized results and there all parameters have a unique scale.
I am using JMP PRO 15.0.0
Many thanks in advance.
Ciao,
Mattia
Jeff_Perkinson
Re: Fix unique scale for all parameters in parallel-coordinates
I'm not sure I understand exactly what you're asking for.
You can control the axis scales for parallel plots in Graph Builder by right clicking on the X axis and choosing from the options.
Does one of those give you what you're looking for?
-Jeff
Jeff_Perkinson
-Jeff
Mattia
Hi Jeff,
Thanks for the answer. This wa exactly what I was looking for, but I did not know where the option was :-).
