hwchoi0109
Fit polynomial over 8
I want to fit polynominal order of 20, but JMP script only allow me to fit polynominal up to 8.
Is there any way that I can do fit polynominal over 9?
Thank you in advance!
Re: Fit polynomial over 8
Select Analyze > Fit Model. Select the predictor column. Change Degree to 9. Click Macros and select Polynomial to Degree.
For example,
hwchoi0109
Hi Mark,
Thank you so much for prompt reply!
I followed your method and it works order of 9 and 10. But, it looks like the maximum order is 10. Is there any way that I can fit over 10, like 11?
Thank you again!
You could build your formula in the formula editor and treat it as if it were a nonlinear function.
Dan Obermiller
hwchoi0109
Thank you for your explanation!
You have answers to your question, but we still do not know the purpose of the plot or the polynomial model. If need a flexible model or interpolator, then you should know that JMP has other options besides a polynomial function for a linear predictor. We have several splines and LOESS, Guassian process models, functional data basis expansion models, and neural networks.
