MSWes
Exporting "Recent Files" for migration to new computer
Hello, I have a user that got a new computer but is upset because her "recent files" when she opens JMP is empty. I still have access to her old computer. Is there a way to export and import these files? I did a google search and there was mention of exporting a registry entry but I could not find the SAS Institute Inc. folder they mentioned in that discussion...
Migrating to new system // List of pinned files
Thanks for any help!
-Wes
Craige_Hales
Re: Exporting "Recent Files" for migration to new computer
I used this in the FileSnapper  addin, the location worked for me on JMP 14 and 15 and probably 16 when released.
temp=runprogram(executable("reg"),options({"query","\["HKCU\Software\SAS Institute Inc.\JMP\Recent\Files"]\"}),readfunction("text"));
I think you can make regedit export that node on the old computer and import it on the new one. You won't need the JSL, just the HKCU bit.
 @jschroedl
Craige
lala
Level IX
1、How to use JMP SOFTWARE JSL to read the contents of the registry branch :HKEY_USERS\SOFTWARE\SAS Institute Inc.\JMP\Recent\Files
wsh = Create Object("WScript.Shell");
reg_path = "HKEY_USERS\SOFTWARE\SAS Institute Inc.\JMP\Recent\Files";
Try(
    reg_values = wsh:RegRead(reg_path);
    If( Is String( reg_values ),
        Show( reg_values );
        For( i = 1, i <= N Items( reg_values ), i++,
            Print( Char( i ) || ": " || reg_values[i] );
2、And how JSL with JMP software implements regedit.exe to import the specified registry file into the registry.
Thanks Experts!
jschroedl
JMP shares the Recent Files list across JMP versions and they are stored per-user under this key:
Computer\HKEY_CURRENT_USER\SOFTWARE\SAS Institute Inc.\JMP\Recent\Files
Here is a picture from my machine.  Be sure you check the registry when logged in as her userid since they are stored in HKEY_CURRENT_USER and the userid matters.
So you ought to be able to login to the old PC as her userid, run regedit and rigt-click Export on the "Files" folder (if you can find it). And have her import the file into her new machine.
John
BHarris
Is this true?  When I upgraded to JMP v18 all of the recent and pinned files were lost, and I was back to a clean slate.  Going back to JMP v17, they're lost there too.  I wonder if something in JMP v18 corrupted the recent files list.
BHarris
I did find the Recent Files in the Windows registry, and exporting/importing the key did the trick, restoring the list of recent and pinned files.
