midori555
Exclude rows in Col Quantile Calculation
I was trying to get Col Quantile( :height, 0.5, :class) but it looks like the calculation would still take the excluded rows into consideration.
Is there a way to reject the excluded rows into Col Quantile calculation?
Thanks,
Midori
Re: Exclude rows in Col Quantile Calculation
You can check for the row being excluded within the Col Quantile() function.  Below is an example
dt << New Column( "Col Quantile Height by Age",
	numeric,
	continuous,
	formula( Col Quantile(If(excluded(rowstate(Row())),., :height), 0.5, :age ) )
Whenever the excluded rowstate changes for the rows in the data table, the formula will calculate new values
	numeric,
	continuous,
I tried to create a loop to collect the 50th percentile of many parameters using the following code, but both elements in "test_list" are the same (they are both 50% of weight). However, if I run the lines manually, it will work. Can I not use the Col Quantile() function in the for loop?
plot_param={
	height,
	weight};
test_list={};
for(plotcnt=1, plotcnt<=nitems(plot_param), plotcnt++,
	pct_50=Col Quantile( If(excluded(rowstate(Row())),., column(plot_param[plotcnt])), 0.5);
	test_list[plotcnt]=pct_50;
plot_param={
height,
weight};
test_list={};
Level XIII
plot_param={
	height,
	weight};
test_list={};
	Eval (Substitute (Expr(pct_50=Col Quantile( If(excluded(rowstate(Row())),., _col_), 0.5)), Expr(_col_), column(plot_param[plotcnt])));
Level XIII
Due to a typo, I just noticed that Eval (substitute()) is enough, even if you substitute 1 with 1:
plot_param = {height, weight};
test_list = {};
For( plotcnt = 1, plotcnt <= N Items( plot_param ), plotcnt++,
	pct_50 = Eval( Substitute( Expr( Col Quantile( If( Excluded( Row State( Row() ) ), ., Column( plot_param[plotcnt] ) ), 0.5 ) ), 1, 1 ) );
	test_list[plotcnt] = pct_50;
show(test_list);
Level XIII
@LatentDataTiger , feedback from JMP Support (TS-00139301)
Yes, this is a bug.  The developers have verified it is a caching issue with Col Quantile [& Col Median] specifically.  The other Col functions do not have the issue.  Using Substitute makes a new expression with each iteration of the loop so that caching does not get used improperly.  Thanks for reporting this and I will file a bug report.
So, under the line, it's not Substitute, but the protection via Eval(Expr()) which fixes the bug.
nice example from @Arn_Cota [adapted version] illustrating the effect:
View more...
test_list = {};
// Without Exclude, returns correct values
	pct_50_v0 = Col Quantile( Column( plot_param[plotcnt] ), 0.5 );
// With Exclude, returns the Quantile for height
	pct_50_v1 = Col Quantile(
		0.5
// With Eval and Substitute, returns correct values
	pct_50_v2 = Eval(
		Substitute(
				Expr(
					Col Quantile(
						0.5
			1, 1
 // use Eval(Expr() to protect the expression against inappropriate caching
 	pct_50_v3 = Eval(Expr(Col Quantile(
		0.5
        // Show different versions
	Show(
		plotcnt,
		pct_50_v0,
		pct_50_v1,
		pct_50_v2,
		pct_50_v3
	test_list[plotcnt] = pct_50_v3;
Level XIII
example/workaround added to Expression Handling in JMP: Tipps and Trapdoors
