BookmarkSubscribeRSS Feed
jb
Sep 23, 2015
Excel VBA - LaunchSet methods used by IR Control Charts
Hello again. I looked at the "analysis" VB.NET sample at:
    C:\Program Files\SAS\JMP\11\Samples\Automation\Visual Basic Samples\Analysis .NET\analysis.vb
Then, from the ControlChart_Click() procedure, I extracted code relating to IR charts (see below).
The code ran successfully...except for the 2 lines of code I added:
  ccontrol2.LaunchSetIRChartParms(True, False, 2)
  ccontrol2.LaunchSetKSigmaAlphaH(True, False, False, 3.0, 1.0)
Please advise on the correct syntax. Thanks!
'Analysis > Control Chart > IR > Individual Measurement
Sub ControlChart()
  Dim app       As JMP.Application
  Dim doc       As JMP.Document
  Dim dt        As JMP.DataTable
  Dim ccontrol2 As JMP.ControlChart
  'Start JMP
  Set app = CreateObject("JMP.Application")
  app.Visible = True
  'Access document and retrieve pointer to underlying data table.
  Set doc = app.OpenDocument("C:\Program Files\SAS\JMP\11\Samples\Data\Big Class.jmp")
  Set dt = doc.GetDataTable
  'Bring the data table to the foreground and make it the active table.
  dt.Activate
  'Create a specific type of analysis object (e.g., ControlChart),
  '  which is used to specify columns and then launch the analysis.
  Set ccontrol2 = doc.CreateControlChart
  'Select column for charting on the vertical axis.
  ccontrol2.LaunchAddProcess ("height")
  'Select column whose values label the horizontal axis.
  ccontrol2.LaunchAddSampleLabel ("age")
  'Select column for By Group processing.
  ccontrol2.LaunchAddBy ("sex")
  'Select the chart type that you want from jmpControlChartConstants (e.g., IR).
  ccontrol2.LaunchSetChartType ((JMP.jmpControlChartConstants.jmpControlChartIR))
  'For the IR Chart, set Individual Measurement option and KSigma parameters.
  'Run the analysis with columns previously specified through LaunchAdd___.
  ccontrol2.Launch
End Sub
jb
Sep 23, 2015
Solution
Re: Excel VBA - LaunchSet methods used by IR Control Charts
Thanks, Brian. Your testing of my code helped point me in the right direction.
I read about the syntax for calling subroutines:
  • If you use the keyword "Call", you must enclose the argument list in parentheses.
  • If you omit the keyword "Call", you must also omit the parenthesis surrounding the argument list.
So there are 2 correct ways to code this in VB:
Call ccontrol2.LaunchSetIRChartParms(True, False, 2)
Call ccontrol2.LaunchSetKSigmaAlphaH(True, False, False, 3#, 1#)
and
ccontrol2.LaunchSetIRChartParms True, False, 2
ccontrol2.LaunchSetKSigmaAlphaH True, False, False, 3#, 1#
briancorcoran
Jun 23, 2011
Hi JB,
I can't help you on this one.  The methods that you mention above worked ok for me.  What kind of error are you getting?
Brian Corcoran
JMP
jb
Sep 23, 2015
Solution
and
