Georgios_Tsim
Dynamic y axis range in variability chart
I have the following variability chart and I am implementing that by Parameter
nebs = {};
For Each({pChoice}, parameterChoice,
lub << append(Text Box(pChoice));
lub << append(neb = Number Edit Box(42));
Insert Into(nebs, neb);
vals = nebs << get;
varchart = Variability Chart( Y( :Value), X( :Time Point, :Storage Condition, :Level ), Std Dev Chart( 0 ), By( :Parameter ), SendToReport( Dispatch( {"Variability Chart for Value"}, "Variability Chart", FrameBox, {Row Legend( :Label, Color( 1 ), Color Theme( "JMP Default" ), Marker( 0 ), Marker Theme( "" ), Continuous Scale( 0 ), Reverse Scale( 0 ), Excluded Rows( 0 ) )} ) ) )
Then, some lines below in the script I add reference lines in each chart using:
obs = varchart << XPath("//OutlineBox[contains(text(), 'Variability Chart for')]");
		count = 0;
		For Each({ob}, obs,
			count = count + 1;
			Report( varchart[count] )[AxisBox(1)] << Add Ref Line(vals[count], "Dotted", Red, "AC", 2);
But some Reference lines can not be observed in the chart because of the scaling of the y axis.
Is it possible to change the scaling for each parameter in this loop so that the max of the y axis range is the maximum between the reference line value or the maximum value of the parameter plus 0.1
Re: Dynamic y axis range in variability chart
You can send << Min / << Max to axisbox to change it's min / max values.
To get the min/max value of column for example by using Col Min/Col Max functions. Optionally you can try to access the marker segment and extract the values from utilizing  << Get Y Values
