lala
Does python write data from memory to JMP only in a circular form?
import jmp;file_path = r"C:\0\test.txt"
data = []
with open(file_path, 'r') as file:
    for line in file:
        row = line.strip().split('\t')
        data.append([float(row[0]), float(row[1])])
dt = jmp.DataTable("New Table", len(data))
col_A = dt.new_column('A', jmp.DataType.Numeric)
col_B = dt.new_column('B', jmp.DataType.Numeric)
for i, (a, b) in enumerate(data):
    dt['A'][i] = a
    dt['B'][i] = b
Does this form work as in the original JSL code?
dt[0,0] = data[0,0]
Thanks Experts!
lala
Re: Does python write data from memory to JMP only in a circular form?
I try it,not word.
data = []
    for line in file:
r=len(data)
print(f"num {b}")
jmp.run_jsl("""
ar=Python Get(date[]);r=Python Get(b);
d2=New Table("test",Add Rows(r),New Column("A"),New Column("B"));
d2[0,0] = ar[0,0]
Scripters Club Recording: Running Python Code within JSL, there are examples in your JMP installation folder \18\Samples\Scripts\Python and I think some in scripting guide Additional JSL-to-Python Examples (jmp.com). More can be found from many presentations by Paul (I also mention these in my presentation from Scripters Club)
lala
This loop form of the code I posted is already implemented.
I'm just wondering if python has this feature
dt[0,0] = data[0,0]
Experts said that I have seen these content, but my English skills are poor, and programming knowledge is not much.Still not solved.
If I had found a way, I wouldn't have spent so much time writing this post.
So ask the experts if they can help.
Which feature? Data table subscripting and setting all values of data table from matrix?
You can set all values with run_jsl
import jmp
file_path = r"C:\Users\jarmo\Downloads\test(1).txt"
data = []
    for line in file:
jmp.run_jsl("""
m = Python Get(data);
dt = New Table("test",
	Add Rows(N Items(m)),
	New Column("A"),
	New Column("B")
dt[0,0] = m
