BookmarkSubscribeRSS Feed
phystudent
Oct 8, 2012
Does anyone else experience JMP crashing when using graph builder standard error bars?
I have entered simple data on 3 columns.  I wanted to make a bar graph and compare means however when I add the error bars it immediately gives me an error and JMP has to force quit, has anyone else experienced this problem???
phystudent
Oct 8, 2012
Re: Does anyone else experience JMP crashing when using graph builder standard error bars?
It is an "exception error"
challiance
Not applicable
Oct 27, 2012
I'm using JMP 10 trial version and I had this problem when trying to add error bars with the pull down menu on the lower right side of graph builder. But if you right click on the graph, highlight bars, then highlight error bars I have been able to add error bars without crashing!! Hope this helps.
