PS
PS
Display probability plots or life distribution function with connected markers
I would like to show probability plots with markers and connection lines between the markers. Currently I am using the "Life Distribution - Compare Groups", which only allows me to chose between markers or lines (lines are stepwise/staircase type with either no vertical or horizontal connection). I could live without markers if I can have both vertical and horizontal lines in a staircase-type plot.
Do you have any idea?
Thanks for your help
PS
PS
Re: Display probability plots or life distribution function with connected markers
i just found the solution myself... There is a "Fail plot" that can be grouped too.
PS
PS
Article Labels
