frankderuyck
Different mixture experiment analysis results JMP 17 & 18
Did something in JMP 18 change in analysis of mixture experiment results. Below is shown that analysis results from exactly the same DOE data sets are different
1. DOE three component mixture
JMP 17 results
JMP 18 Results
2. DOE three mixture components + one process effect
JMP 17 results
JMP 18 results
In JMP 18 analysis above the model is different!
What has changed and why? Remark: despite of different plots & model graphs of JMP 17 - 18 prediction profilers are identical.
Victor_G
Re: Different mixture experiment analysis results JMP 17 & 18
Hi @frankderuyck,
I might have found a clue about the difference in plots.
  • In JMP 17, when you extend the ranges of "Actual by Predicted" plot, it seems the plot is constructed by using a response mean of 0 (confidence band is symetrical around 0):
    So maybe the modeling without intercept of mixture models was (incorrectly ?) translated into a modeling with intercept = 0, hence the confidence band being large and non-symetrical around the response mean.
  • In JMP 18, you don't observe this situation as confidence band are symetrical around the response mean (5,88) :
Curious to know if any developers might confirm or inform about this difference in plots. @Ryan_Lekivetz ?
Best,
Victor GUILLER
frankderuyck
Find below feedback from JMP technical support, this is in agreement with the anwer of Vicotor above:
The difference you noted between JMP 17 and 18 was due to the Actual by Predicted plot not appropriately accounting for the "hidden" intercept in mixture models. To answer your last question in the community thread, the modified calculation of the confidence interval will persist into future versions.
22 REPLIES 22
Victor_G
Hi @frankderuyck,
In the first case, can you provide anonymized dataset ? Are the columns properties the same ?
In the second case, the models are different in the two captures. You should have similar results by having the same models.
Victor GUILLER
frankderuyck
My first three component case study above was similar to the one presented in a known earlier JMP webcast vinegar/oil/water case study below, you can see that the plot is also similar to mine but not the same in JMP 18
frankderuyck
I remeber that the explanation for the wide confidence interval was the strong collinearity among the mixture effects which makes sense; this does not show up anymore in the JMP 18 plot (?)
frankderuyck
The link to the webinar is https://community.jmp.com/t5/JMP-Blog/Summer-DOE-Series-Mixture-DOE/ba-p/669012
I got green light to use this data set for my DOE training
Victor_G
Hi @frankderuyck,
I would compare the outcomes of the first use case on something else than p-values, due to multicollinearity in mixture designs.
Again, without any dataset to test, it's difficult to help you since we have only a partial view at this comparison.
For the first use case, if the model are set up correctly and in the same way between JMP 17 and 18, try to look at the Parameter estimates (and standard deviations), at metrics focussed on predictivity and optimization (like RMSE) and residuals/diagnostic plots.
Since you mentioned the Profiler has similar results between versions, I would guess that the differences you are seeing are mostly due to the use of Mixture designs instead of a calculation change between versions.
Victor GUILLER
frankderuyck
 Find in attachment the DOE analysis data set
During my september training I still used JMP 17, trainees got JMP 18, it was a big surprise and annoying that my 17 training results were different! Mine are similar (same data) to those presented in webinar above, think also with JMP 17.
Strange, I used your data table and analyzed in both 17 and 18.  The only difference I found was the confidence limits on the Actual by Predicted  plots (leverage).  All of the other statistics were identical (I used your scripted fit model).
JMP18
JMP17
frankderuyck
Indeed question is why?
frankderuyck
The jmp 17 plot is should be more accurate because of the very strong collinearty among mixture components; limits from jmp 18 are to my opinion too narrow?
