UserID16644
Decimal to Hexadecimal
How to convert a decimal column to hexadecimal?
Jun
Jun
Re: Decimal to Hexadecimal
Jun
Jun
have you tried this?
UserID16644
Hi, @Jun
I would like to have like this format:
Jun
Jun
UserID16644
Not working for me, where does "integer" came from?
Edit: Already worked, I changed the data type into Numeric. Thank you
