lehaofeng
Level V
How to determine if it obeys a chi-square distribution?
I want to determine whether a set of data obeys a chi-square distribution, how do I do this with JMP? Thanks!
I looked at the distribution-continuous fit and didn't find this distribution.
MRB3855
Re: How to determine if it obeys a chi-square distribution?
Hi @lehaofeng : The Chi-squared distribution is a special case of the Gamma distribution.
Statistical Details for Continuous Fit Distributions (jmp.com)
So, you could start via trying to fit a Gamma distribution. If it doesn't fit a Gamma, then it can't be a Chi-squared. If, however, it is Gamma...then it might be Chi-Squared. Try that then come back.
MRB3855
lehaofeng
Level V
Thanks. I'll look into it.
