Martin
Level V
Data Filter Date/Time with extra ".0"
I have a column with a Date and Time in it (see graphic for formatting).  When I use a Global or Local Data Filter, the dates/times show up as MM/DD/YY H:M:S.0 with the ".0" being extraneous (see graphic for data filter).
Does anyone know how to get rid of the ".0" in the data filter?
Thanks
Re: Data Filter Date/Time with extra ".0"
If you set the following Custom Format for you date column, the Local Data Filter will drop the .0
Char( Format( :value, "m/d/y" ) ) || " " || Char( Hour( :value ) ) || ":" || Char( Minute( :value ) ) || ":" || Char( Round( Second( :value ) ) );
Martin
Level V
 Thanks @txnelson, I will try that. But it appears you are saying I need a new "second" date column for this to work - is that correct?  I guess another way to approach this is to use a For Each Row and replace the data that is there with this new value.
Martin
You do not need a new column.  Second() is just a function that extracts the number of seconds value from the Date/Time column
Attached is the example data table I used for my last response
