Created:
Feb 8, 2022 03:29 PM
| Last Modified: Jun 9, 2023 11:10 AM(2957 views)
I have a column with a Date and Time in it (see graphic for formatting). When I use a Global or Local Data Filter, the dates/times show up as MM/DD/YY H:M:S.0 with the ".0" being extraneous (see graphic for data filter).
Does anyone know how to get rid of the ".0" in the data filter?
Thanks @txnelson, I will try that. But it appears you are saying I need a new "second" date column for this to work - is that correct? I guess another way to approach this is to use a For Each Row and replace the data that is there with this new value.
