bittnere
Custom Date Format in JSL Script (For Query Builder)
Overall Goal: Create a query in Query Builder that filters on a date time column only pulling data from the last 7 days of the current time. I am trying to use a custom expression in Query Builder to do this. Ideally it would just be the following in the custom expression filter but it results in no data pulled.
t1.TimeCol >= format((Today() - InDays(7)), "m/d/y h:m:s")
It appears Query Builder takes a specific date time format for its WHERE statement, 'y-m-d h:m:s' (i.e '2022-07-07 11:13:55'),  for which JMP doesn't have a built in format for. Therefore I created a custom date format shown below using this example. In a data table it converts a date time column to the custom format as expected. I am struggling to call the format in jsl code though as I get a "Unknown format: myNamespace:QueryDate" error. Any insight? Thanks!
print(format(Today(), "m/d/y"));
print(format(Today(), "myNamespace:QueryDate"));
Custom format:
Add Custom Functions(
New Custom Function(
"myNamespace",
"QueryDate",
Function( {inputVar},
{Default Local},
Char( Year( inputVar ) ) || "-" || Char( Month( inputVar ) ) || "-" ||
Char( Day( inputVar ) ) || " " ||
Char(Hour(inputVar)) || ":" || Char(Minute(inputVar)) || ":" || Char(Second(inputVar))
<<Description(
"Date format for query builder y-d-m h:m:s"
<<Custom Format Category( 1 )
Georg
Re: Custom Date Format in JSL Script (For Query Builder)
If you compare a datetime column at database, you need a datetime value for the comparison, but format returns a string. So this will not work so far as I can see. You would need to convert the datetime string at database to a datetime value.
But for your task you can avoid this problem, by simply taking the current date from the database and subtracting some days, and implement this as a custom expression in the Query Builder,
but the syntax will depend on database.
For ANSI it may look like this:
t1.datetime > addday(now(), -7)
and for Oracle it may look like
t1.datetime > sysdate - 7
Georg
Georg
