    Regular business hours will resume at 9:00 a.m. ET on Friday, Jan. 2, 2026.
Aki
Aki
Uninstall JMP PRO 16 silently
I want to uninstall JMP PRO 16 silently, i have tried with the below command but it is not working, looks like this stuck because of below pop up message
"C:\Program Files (x86)\InstallShield Installation Information\{61DF41B1-9877-4906-80C4-09941A05BD77}\setup.exe" -runfromtemp -l0x0409 -removeonly /s
Re: Uninstall JMP PRO 16 silently
There needs to be a reference to the silent uninstall script file in your command.  When you uninstall from a command line with a  -r  at the end of the command line, the uninstall script will be recorded with an  .iss  file extension.  The, update your command to reference the  .iss  file.  Note that there is no space after the "-f1"
"C:\Program Files (x86)\InstallShield Installation Information\{61DF41B1-9877-4906-80C4-09941A05BD77}\setup.exe" -f1C:\full_path_to_uninstall.iss -runfromtemp -l0x0409 -removeonly /s
- Bob Hickey
lwx228
Level VIII
Copy the JMP folder to another path first.Then uninstall the original installation.In this way, the newly copied JMP will still work well in the future.
