Teissduc16
SQL query script problem with date format
I'm a biginner on JSL. I'm mixing a script with a SQL Query. My query conditionned by two date. But when I run it the assignement of my date deosn't work. The fild with the date is _TIMESTAMP and the format of the date is yyyy-mm-dd hh:mm:ss. When I run it with the dates inside the query of course it works. I need this script because I have to do the same thing for numerous tables.
Here is the script :
RunScript= Expr(
  sql_statement=evalinsert("SELECT * FROM table_SQL WHERE  _TIMESTAMP >= '^start^' AND  _TIMESTAMP < '^end^' ");
  start=(2021-12-15 00:00:00);
  end=(2021-12-18 00:00:00);
  Open Database("Driver=§§§§§§§§§§§§§§§§§§§§§§§§",
  sql_statement,"table_name_1"));
I have blinded the sql connexion parameters.
Kind regards,
Re: SQL query script problem with date format
sql_statement will error if you don't have start and end defined before the eval insert statement, also change start and end to strings
//this will error because it is before start and end variable definition
//sql_statement=evalinsert("SELECT * FROM table_SQL WHERE  _TIMESTAMP >= '^start^' AND  _TIMESTAMP < '^end^' ");
start = "2021-12-15 00:00:00";
end = "2021-12-18 00:00:00";
show(sql_statement);
//sql_statement = "SELECT * FROM table_SQL WHERE _TIMESTAMP >= '2021-12-15 00:00:00' AND _TIMESTAMP < '2021-12-18 00:00:00' ";
ih
Super User (Alumni) ih
Welcome to the community @Teissduc16,
A couple of small things that might help:
  • You probably want to define start and end before you use them in the eval insert() line.
  • To make sure the date shows up in a format SQL understands, you probably want to format dates as strings before putting them in the sql statement
Here is an example:
start=("2021-12-15 00:00:00");
end=format(date dmy(1,1,2021), "yyyy-mm-dd hh:mm:ss");
Teissduc16
Thank you very much for your answer. It returns well what I want.
Regards
