pjkiley
Creating presets for JMP plots, especially through graph builder
Dear all,
I find I am always having to do the same set of actions whenever I create a plot.  This includes changing multiple font sizes, changing the fonts to match a document, changing the background color, changing line widths, chaning aspect ratios, and many other things.
Therefore, I am wondering if there is a way to create preset graph or plot appearances such that I could change all of these things at once.  Ideally it would be nice to have  set of these, so that I can easily change the plot appearance for different final purposes.
Thanks very much!
Re: Creating presets for JMP plots, especially through graph builder
You handle this by setting the Graph Builder Platform's Preferences
     File==>Preferences==>Platforms==>Graph Builder
You may also want to look in the Preferences at the Graphs and the Styles sections for other preferences you may want to set.
pjkiley
Thanks!  However I only seem to be able to set background color this way.
What about:
1) axis label font
2) axis label size
3) axis line thickness
4) storing multiple presents for different purposes
Thanks again for your help
pjkiley
Just figured out that the rest of the settins are under the Fonts preference.
