취소
다음에 대한 결과 표시
표시  만  | 다음에 대한 검색
다음을 의미합니까?
언어 선택 변환 막대 숨기기
CharlesIII
Creating a subset of data based on a list of columns
I have a large data file with many columns of data. I would like to create an automated way to subset the raw data based on a list of columns.
If this table is my raw data
12345678910
and my list of columns that I would like to subset may be [1,4,6,9]
I want to generate a new table that looks like this
1469
The reason I can't just hardcode what columns to take is the list will is updated every so often so I would like a more hands-free way of dealing with this.
If I need to provide more information let me know.
1 채택된 솔루션
채택된 솔루션
cwillden
Re: Creating a subset of data based on a list of columns
This is probably really easy, but I'm confused about your list.  You say you can't hardcode in which columns to use because it will change, but doesn't someone need to ultimately enumerate the columns to use when the list gets updated?  Otherwise, where does that list come from? If you have a variable right at the top of the script that enumerates all the columns to use, is that sufficiently easy to maintain?  If so, here's a simple script that does that:
//list of columns
subset_cols = {:Name("1"), :Name("4"), :Name("6"), :Name("9")};
dt << Subset(	All rows, columns( subset_cols ) )
-- Cameron Willden
원본 게시물의 솔루션 보기
5 응답 5
cwillden
//list of columns
-- Cameron Willden
Niros
This doesn't work for me when I use:
SubTable3[i] = Tables[i] << subset( selected rows(1), columns(Column(MT_Col_Names[1]), Column(MT_Col_Names[2]), Column(MT_Col_Names[3]), Column(MT_Col_Names[4]), Column(MT_Col_Names[5]), Column(MT_Col_Names[6])), Invisible);
The error is:
And if I change 'columns' to 'As columns', It works (no error), but all columns show up...
Thanks for any help,
Nir
cwillden
I don't think its necessary for you to enumerate all the items you have in MT_Col_Names or to wrap those in Column().  What type of data is inside "MT_Col_Names"?
Here's a working example with a list of strings representing the names of the columns I want to keep:
dt << Select Rows({1,2,3});
sub_cols = {"name", "age", "sex"}; //same role as MT_Col_Names
dt2 = dt << Subset(selected rows(1), columns(sub_cols));
-- Cameron Willden
jj_jmp
Maybe try
eval(evalexpr((
As Column(expr(MT_Col_Names[1])), As Column(expr(MT_Col_Names[2])) ), Invisible);
jj_jmp
eval(evalexpr(
추천 글
