Hans_Hsu
Create count analysis like excel pivot
In this file, each row has its own volume value, I would like to have a summary table showing that:
volume = 1,  239 counts,
volume = 2,  201 counts
volume = 3,  92 counts
.....etc
How to make this kind of table?
Re: Create count analysis like excel pivot
  1. Change the modeling type for your Volume column to Ordinal
  2. Go to the pull down menu        Analyze=>Tabulate
  3. Drag column Volume to the Drop zone for rows
If you want the data in a data table, just click on the red triangle and select Make into Data Table
OR
  1. Go to pull down menu      Tables=>Summary
  2. Select the Volume column from the Select Columns box and click on the Group button to add it to the Group selectionvolume3.PNG
  3. Click on OK
I encourage you to take the time to read the Discovering JMP document under the Help pull down menu
OR
  3. Click on OK
