Please check out JMP's "Value Labels" property, as well as the "Labels to Codes" and "Codes to Labels" columns utilities.
I would be remiss if I did not advocate for the use of numeric 1 for POR and 0 for test (1: test and 0: POR if you prefer). Using the Value Label column property, we can make these values APPEAR as if they are "test" and "POR", but internally, they are 0s and 1s.
Since the values are numeric, computations can be done using native column and row formulas. In the case of 1s and zeros, the sum gives the number of 1s, while the mean gives the proportion of ones. In this example, if we store POR as 0 and "test" as 1, we can find the number of tests in a given row simply by selecting all columns of interest, right-clicking and choosing New Formula Column > Combine > Sum from the pop-up menu.
Below is an image of how this looks in practice. The cells appear to contain text, as the words POR and test are left-justified, but when you click on a cell you can see that in fact JMP is storing a number internally, similar to what is done with dates and times.
By clicking on the * to the right of the column names in the Columns pane (left center of data table), we can select "Value Labels" to view the current settings of the property:
Cheers,
Brady
