shazaaliah
How to use text to column methods but without manually renaming all the splited columns afterwards?
How do I use the "text to column" method but without manually renaming all the splitted columns afterwards?
Re: How to use text to column methods but without manually renaming all the splited columns afterwards?
 How would you want the new columns named?
There are a few ways to do this.
Scripting:
dt = open("ExTable.jmp");
//find column position of column to be split
columnPosition = contains(dt << get column names(string), "CombinedFields");
//determine original number of columns
originalNumCols  = ncol(dt);
//new names here...
newColNames = {"Model", "Country", "Type"};
//split the column
dt << Text to Columns( columns( :CombinedFields ), Delimiters( "," ) );
//how many new columns are there?
numColsCreated = ncol(dt) - originalNumCols;
//loop through the new columns, using original column's position as an offset, and change names
for(i = 1, i<=numColsCreated, i++,
	column(dt, columnPosition + i) << set name(newColNames[i])
Cut and paste:
Place the new column names in a single column of a table, select them all, and copy them with a CTRL-C (CMD-C on Mac).
Perform the Text To Columns operation, then select the new columns and press CTRL-V to paste the new names.
Using Recode Column Names
First, use Text To Columns to split the column of interest.
Next, Select Cols > Column Names > Recode Column Names... from the main menu.
Enter the new column names as desired, then click the Recode button to finish.
Table and script attached.
Cheers,
Brady
