NTPSV113
Correlation plots- How to split data by a grouping variable
I need help with plotting correlations.
Attached below is the dummy data set.
  • Plot needs to have data for samples on X and Y axis based on Type
  • Correlations at Gene level by sample, meaning take an average of reads by gene per sample and plot correlations of the average
  • Correlations at read level by sample
Thank you.
NTPSV113
Re: Correlation plots- How to split data by a grouping variable
Received help from JMP Tech Lead. Below is a link to the video describing the steps.
https://share.vidyard.com/watch/SuXnsN1bhCtycJPFcW5wPB?
NTPSV113
