How can I copy a JMP graph without getting the getting the gray background?  I saw in another discussion (see below) that this can be done with add-in file, but how do I add an add-in file?  Where do I double-click the downloaded file?
From a prior discussion:
This add-in adds a menu item (under the Add-ins menu) to copy the currently selected item in JMP without the default window background. This is especially useful when copying graphical output to a document with a white background (such as publications and websites).
Instructions for use:
1. Install add-in by double-clicking downloaded file.
2. Select a graph using the selection tool (fat plus sign).
3. Select "Copy without background" from add-in menu.
4. Paste graphic to desired program.
