Converting a number in one column to a word in another column
Aug 21, 2018 10:45 AM(7546 views)
Hi all,
This is probably covered elsewhere but I couldn't find it. I'd like to make a formula that will give a specific word for a given value in a separate column. See below:
Another option is to use recode with the formula column option (drop down in upper left of dialog), click ok when asked if you want to convert to character (JMP converts the new column to character). The result is as provided by Jim but with JMP doing the formula writing.
Thanks Karen!
I thought there was a way to do it like this. I was struggling with the match formula.
KH
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '69031' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '69031') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '69031') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
