lwx228
Continue asking about Regex segmentation
I made a mistake.Writing code like this doesn't get you the right result.
c=Regex("abcdef{:[[ghi]]:[{op},{q}]}", ":\[\[]\([^\]]*)\]", "[\1]");
Need to get:
[{op},{q}]
So how to write JSL. Thank you very much!
Craige_Hales
Staff (Retired)
Re: Continue asking about Regex segmentation
JMP 15 does a pretty good job with this JSON data (rename the file from .txt to .json, it will be easier @Justin_Chilton ); JMP 14 does not appear to handle this json case correctly. Here's the JMP 15 import using best guess, and adding the stack option:
Best Guess is under the red triangleBest Guess is under the red triangleyou might want to do two imports like this:
get the little table of column namesget the little table of column names
get the bigger table of dataget the bigger table of data
You can leave out columns you don't want. You could apply the column names from the little table to the big table, renaming value0 to 2018.
Craige
Craige_Hales
Staff (Retired)
If the data is json or xml, you should use JMP's json/xml parser. It is not easy to write a parser for these nested structures, and regex alone is not enough. Importing the xml/json to a table and then finding the row and column is a great choice.
If the data must be handled some other way, you could do it with just a simple JSL loop and a bunch of regex tests, something like this:
txt = loadtextfile(...);
ok=1;
while( ok,
 ... try various regex that remove a bit of data from txt ... set ok to 0 if nothing works.
That works for small files and can be easily maintained. But a large file with many bits of data will be too slow because removing a bit of data from a large txt string copies a lot of data, for each removal. (it is an n^2 problem: doubling the file size will 4X the run time.)
For large files, it is best to write a single pattern match that does not modify the input string. You can use regular expressions or patterns within a patRepeat() pattern that matches the entire file, and you'll use patTest(... ;1) to run some JSL inside the match that saves the parsed results into a JSL matrix or list or associative array. Before JMP had a built-in json parser, @XanGregg and I wrote some JSL to parse json files. It is still a great example, but JMP's built-in parser is better.
Here are some other posts that have JSL that parses a file using patMatch(... patRepeat( pattern ) ... )
https://community.jmp.com/t5/Uncharted/The-Other-Kind-of-Model/ba-p/231703 parsing a data file for a 3D model
https://community.jmp.com/t5/Uncharted/Web-Logs/ba-p/29389 parsing an Apache log file
https://community.jmp.com/t5/Uncharted/WordNet/ba-p/28984 parsing wordnet file
https://community.jmp.com/t5/Uncharted/Pronounce-Elephant/ba-p/21272 parsing the CMU phoneme file
I often use the >>log() function to debug complicated pattern matches.
https://community.jmp.com/t5/Uncharted/Backtracking-Secrets/ba-p/20984 using the >>log() for debugging
and
https://community.jmp.com/t5/Uncharted/Pattern-Matching/ba-p/21005 introduction to patMatch()
https://community.jmp.com/t5/Uncharted/Regex/ba-p/21008 introduction to regex()
Craige
14 REPLIES 14
lwx228
It doesn't work either:
c=Regex("abcdef{:[[ghi]]:[{op},{q}]}", ":\[\[]{([^\]]*)\]", "[{\1]");
Here is how I would do it:
x = "abcdef{:[[ghi]]:[{op},{q}]}";
c=word(1,word(3,x,":"),"]") || "]";
Ryan_Gilmore
Here's a potential alternative:
c = Regex( "abcdef{:[[ghi]]:[{op},{q}]}", "\!\[(\{\w+\},*)+]" );
Another form:
Names Default to Here( 1 );
string = "abcdef{:[[ghi]]:[{op},{q}]}";
c = Regex( string, "\{:.+:(.+)\}", "\1" );
lwx228
The above code for actual data is still not up to scratch.
I don't think I found the key.
Please invite experts to continue the guidance.Thanks!
The actual text is much more complex than the example that you posed and we solved.
You posted this problem before. I tried then to first convert the text to a JMP list and then iterate over the items, rather than trying to work with the whole text. JMP fought me the whole way and nothing I tried worked. Perhaps someone else knows how to get a list. It seems so simple. I think that processing the strings with Regex() would be much more straight-forward with the text broken up into list items.
lwx228
I don't know enough.
I thought it was just partition
Start with :[{
and end with the second}]
so can get [{...}] and between them.
It seems that my original understanding was too hasty.
Thanks!
lwx228
I got two orthogonal codes in the VBA community, but I still won't change them to JSL code.
Ask for expert guidance.Thanks!
Sub t()
 Set reg = CreateObject("vbscript.regexp")
 reg.Pattern = "^(?:.*?(\[.*?]))*|."
 reg.Global = True
 Cells(1, 2) = reg.Replace(Cells(1, 1).Value, "$1")
 End Sub
lwx228
The other code is
