LNitz
Connecting to SAS on the current machine
I think I once learned how to connect JMP to SAS on the current machine.  I have changed machines, and cannot reproduce the procedure.  When I select SAS from the File Menu and then Connections,  and choose to connect to the local machine SAS installation, I usually get the following error code:
"A connection to machine "127.0.0.1" could not be established on port 8561. Verify that the values provided for machine name and port are correct."
I can tell I am not connecting, because the Select Data screen describes a differen collection of libraries than on my working machine.
I wish to import SAS files into JMP with the SAS formats attached.  When I can make the connection work (not sure of by which procedure, but rarely), I can import only the SAS file without the formats, even though the library named in the SAS routine I ran from JMP contains the format library.
What does it take to assure that the connection can be made within the same machine?
At this point, I appreciate any help, however silly it might make me look!
Thanks
Re: Connecting to SAS on the current machine
I believe that you need to contact the JMP folks on this
     support@jmp.com
