This is the setup (I've always had this problem with JMP, never solved row order graphs!).
Stacked data (3 datapoints per ID (setting A/B/C), two groups (A/B).
I would like to make a graph with mean SD, or a boxplot, with individual data points.
Sample dataset provideed.
