Aziza
Compare Analytical Methods (Pharma) in JMP
Dear Community,
Can you please share some of your thoughts/references/... to compare two Analytical Methods in JMP?
I found there is a JMP Add In which was shared in the community (Method Comparison - JMP User Community) in 2014, but i was wondering if there is a new way of doing it in JMP meanwhile....
Thank you.
Greetings
Re: Compare Analytical Methods (Pharma) in JMP
JMP 17 introduced Passing-Bablok Regression to the Bivariate platform:
The curve menu for this fit under the scatter plot provides a new command to start the new Bland-Altman Analysis in the Matched Pairs platform.
Aziza
Thank you so much @Mark_Bailey for your input! This was exactly what I was looking for! Merci! :)
Greetings
Aziza
Greetings
