Aziza
Comment/Uncomment out portions in the script
Hi all,
does any of you know how to comment out the portions of the script in JMP?
Thank you!
Greetings
Re: Comment/Uncomment out portions in the script
Select the portion you want to change and then right-click in the script window. Select Advanced > Comment Block or Uncomment Block.
pmroz
And if you want to do it manually, JMP uses C++ style comments.  Either surround the code to be commented out with /*   */, or start each line with //.
// Uncommented:
pi = 3.14159;
e  = 2.71828;
// Commented out using /* */
pi = 3.14159;
e  = 2.71828;
// Commented out a different way
// pi = 3.14159;
// e  = 2.71828;
pmroz
// Uncommented:
pi = 3.14159;
e  = 2.71828;
pi = 3.14159;
e  = 2.71828;
// pi = 3.14159;
// e  = 2.71828;
Aziza
fantastic! Thank you!
Greetings
bswedlove
Is there a keyboard shortcut to comment/uncomment a block of code?
Review of the Menu Card for the Script Editor
     Help==>Books==>Menu Card
There is not a keyboard short cut for commenting blocks of text
JPoindexter
If anybody thinks there should be better keyboard shortcuts for commenting, you should vote for this suggestion:
https://community.jmp.com/t5/JMP-Wish-List/Keyboard-Shortcut-to-Comment-Code-in-Script-Editor/idi-p/...
