Rachelh6
Column Value Ordering Malfunction
Hello all,
I am trying to find if I have any significant differences between my slopes for a category.. When I try and change the value orderig in order to get all the slope comparisons it won't update on my analysis and I dont know why. It will have changed in the value ordering dialouge box but not in my analysis.
Re: Column Value Ordering Malfunction
What platform is this?  If you go to the Red Triangle Menu and then select Redo, is "Automatic Recalc" checked?
Rachelh6
Its JMP 14 and no the auto recalc is not checked
You could check "Automatic Recalc" or choose Red Triangle Menu > Redo > Redo Analysis to recreate it with the updated data.
