Level XIII
Color setting for highlighted text in Tabulate
Highlighted entries in Tabulate get a blue background.
Is there a way to change the font color of such highlighted entries (to white?) - such that the highlighted text is more visible?
The blue/white colors for highlighting in tables is perfect:
Re: Color setting for highlighted text in Tabulate
Hi @hogi - JMP 17 has included changes to Tabulate to update the color of selected text in a way that follows most other reports.  These are not fixed settings, but based on the system settings for color.  If you were to change to a high-contrast setting, Tabulate and most other text should use colors consistent with the settings.
I cannot find any way to accomplish the white text on the blue background with selected cells in Tabulate. Perhaps someone else knows how to do it. Otherwise, you might check the Wish List area of the JMP Community to see if someone else has already suggested this feature. If so, please vote for it! If not, then add it as a new request.
Level XIII
