BookmarkSubscribe
smushieduckface
Color gradient based on absolute value?
I am trying to color a column based on the sigma distance from target instead of from lowest to highest.
For example, I want a color gradient from the smallest value to the largest value so from 0.07 to 0.64 (with -0.54 having the same color as +0.54). I do want to keep the negative signs so that I know which side of the target it is on.
Here is some example data:
0.07
-0.24
-0.54
-0.26
-0.64
0.09
0.30
0.03
-0.15
0.54
Is this possible to do in a JMP script? Any ideas?
Thanks!
Re: Color gradient based on absolute value?
I've attached a small example script that colors "height" column cells in BigClass.jmp according to a distance from a  target value.
Here's a sampling of the result using a target of 60.
Notice that 59 and 61 have the same color because they're both 1 away from the target.
I hope you will be able to adapt the script to your data table.
XanGregg
Two possibilities:
  1. Create a new column which is the absolute value of the first and use that for color, but still use the first column for labeling.
  2. Create a custom color gradient that's symmetric. For instance, black to white to black with a centered value scale. If you really need 0.07 to be the minimum, you can create a constant color zone in the middle. That is black-to-white-to-white-to-black.
smushieduckface
Thank you so much! I had tried the second option but it didn't seem to work unless the range was equal on both sides.
John, your script worked great. I really appreciate it. Thanks!
