NathalieWojta
Changing frame size of just one of two parallel graphs in graph builder?
Hello everyone,
I am still quite new to jmp and I hope, I was not hopelessly blind and did oversee an already existing topic. I am a pro at this one.
So, my problem is:
I want to create box plots that first start with all results plotted in one box followed by the results of different collectives. I was able to create this kind of figure using the Graph Builder by creating two parallel graphs (see picture below: reality). But I would like the first diagram to be smaller (wish). Not only because this approach would safe a lot of space but also because it facilitates the understanding of the picture. Is it possible, to fullfill my wish? Thank you all in advance.
gzmorgan0
Re: Changing frame size of just one of two parallel graphs in graph builder?
Hold down the ALT key and just below the lower right corner of the ALL area click (a dashed box appears)  and drag the left edge of the dashed box to the left.
To be fair, I always forget this key sequence and never achieve the size I want.  Since I do a lot of scripting, I prefer to set it specifically with a script.  Using your graph, click the red menu and select Save Script to Sript window. Then add a Relative Sizes() statement like the one below, and rerun the script (right click and select Run).
Here is an example using Big Class, the script is shown below the picture
Names default to here(1);
Open("$sample_data/big class.jmp");
//left frame is 120 pixels wide, which is one third the size
//of the right frame that is 360 pixels wide
Graph Builder(
	Size( 511, 330 ),
	Variables( X( :sex ), X( :age ), Y( :height ) ),
	Relative Sizes( "X", [120 360] ),
	Elements(
		Position( 1, 1 ),
		Points( X, Y, Legend( 9 ) ),
		Box Plot( X, Y, Legend( 11 ) )
	Elements(
		Position( 2, 1 ),
		Points( X, Y, Legend( 10 ) ),
		Box Plot( X, Y, Legend( 12 ) )
12 REPLIES 12
I am not able to see your Reality and Wish graphs.  All I see are the words, Reality       Wish
NathalieWojta
The colours are really light, I apologize. I have itensified them and hope, the images are visible now:
gzmorgan0
Graph Builder(
	Size( 511, 330 ),
	Elements(
		Position( 1, 1 ),
	Elements(
		Position( 2, 1 ),
Wow.......I am in total awe of of you Ms. M.
gzmorgan0
Back at you!
NathalieWojta
Good morning and thank you for the solution. :)
That was as easy as I had feared it to be. I apologize for my blindness and wish you all a wonderfull week!
markschahl
Just found this and used it. Thanks!
One thing I found is that the list can truly take relative sizes not in pixels. I built a two panel graph with [125 375]. I tried [1 3] just for grins. Got the same result.
DO NOT comma separate the elements in that list. It won't run. Took me 20 minutes to figure out what my mistake was...
Joseph_Reese
Thank you!! Have been wishing I could do something like this for awhile. There are so many helpful tips hidden in these message boards. I wish JMP would have a "tip of the day" option I could turn on specifically for JSL that would give hints/tips like this.
rbfinner
I can use this! Thank you.
Is this option - of setting a relative size ratio for axis - available through the interactive graph builder interface also? (I couldn't find it)
