Hi Team,
It's kind of I'm stuck, I want to change the data type of a column when plotting.
Explanation : My original data type is "numeric and continuous" but I want to change the data type to "character and nominal" via JSL. It is needed because visual analysis of plots are not very impressive as we can see here
![Sukanyap_0-1687513616469.png Sukanyap_0-1687513616469.png](https://community.jmp.com/t5/image/serverpage/image-id/54098i64FD6FEAD9920FB0/image-size/medium?v=v2&px=400)
And with data types changed it's acceptable
![Sukanyap_1-1687513663281.png Sukanyap_1-1687513663281.png](https://community.jmp.com/t5/image/serverpage/image-id/54099i6A2F3AEC8A758B8C/image-size/medium?v=v2&px=400)
1) I'm using JSL for plotting using Graph builder, by any chance can I change here in below line beside "user density" while plotting?
![Sukanyap_2-1687513840440.png Sukanyap_2-1687513840440.png](https://community.jmp.com/t5/image/serverpage/image-id/54100i5088DC2328A82B76/image-size/medium?v=v2&px=400)
To explain more here, though I'm changing the data and modelling types but it seems JMP is not processing the below line arrow marked
![Sukanyap_3-1687514008520.png Sukanyap_3-1687514008520.png](https://community.jmp.com/t5/image/serverpage/image-id/54101i8B35532DB5EEAD9E/image-size/medium?v=v2&px=400)
Whereas when I'm using this open function code is working as desired and JMP is reading the user density data type and while plotting it's giving desired results.
![Sukanyap_4-1687514211169.png Sukanyap_4-1687514211169.png](https://community.jmp.com/t5/image/serverpage/image-id/54102i9798E3430E620777/image-size/medium?v=v2&px=400)
