Change the data filter display in JMP19
I am currently migrating an application from JMP 18 to JMP 19. In the process, I have noticed a change in behavior (JSL) regarding the Data Filter.
In the application, I create a data filter with many columns (>10). I had gotten into the habit of changing the data filter’s display using the command << n col(3) to spread my more than 10 filters across 3 columns (less visually cluttered). In JMP18, this worked (see script below).
JMP18:
JMP19:
In JMP19, it has no effect... Has anyone else encountered this issue and found a workaround? Having the entire data filter displayed vertically is too cumbersome, yet I’d still like to use JMP’s data filter object, which is very convenient for selection.
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
obj = dt <<
Data Filter(
	Add Filter(
		columns( :Region, :POP ),
		Where( :Region == {"C", "N"} )
	Mode( Select( 0 ), Show( 0 ), Include( 1 ) )
wait(0.1);
 (obj << report)[Lineup Box( 2 )] << ncol(2)
Try( (obj << report)[ListBoxBox( 1 )] << set size( 200, 150 ) );
Try( (obj << report)[Framebox( 1 )] << Frame Size( 200, 20 ) );
Thanks in advance !
Re: Change the data filter display in JMP19
There is at least one post in the JMP community regarding this same change -> JMP19 did change display box structure of filters and how the elements are placed within Lineup box. If I remember correctly there are really no good workarounds and I have built my own filters because of that.
Hello, thank you for your answer, I have thus add a suggestion in the Wishlist https://community.jmp.com/t5/JMP-Wish-List/Data-Filter-allow-specifying-number-of-columns-for-the-fi... in the mean time
It looks like the LineupBox has changed to no longer position both of the 'columns' as each of the V List Boxes for the filters, if you run (obj<<report)[LineupBox(2)]<<get script it produces this:
Lineup Box(
	V List Box(
		SpacerBox,
		Border Box(
			Border Box(
				V List Box(
					Border Box(
						Tab Page Box(
							Title( "Region (6)" ),
							Closeable(),
							V List Box(
								V List Box(
									If Box( H List Box( FilterFieldBox ) ),
									V List Box( ListBoxBox )
					Border Box(
						Tab Page Box(
							Title( "POP" ),
							Closeable(),
							V List Box(
								Border Box(
									ScaleBox(
										V List Box(
											FrameBox,
											DFIntMinMaxBox(
												NumberEditBox, NumberEditBox
You would expect both of the 'Border Box' items to be next in the heirachy after the LineUp Box to line up with the 'Cols'.
If you run (obj<<report)[LineupBox(2)]<<get n cols you can see it is set to the value of '2' that you set as well.
Thanks,
Ben
