See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
Change the Legend Location in Graph Builder
faraz
Is there a way to change the location of the legend from the default (right side) to somewhere on the plot in Graph Builder?
julian
Re: Change the Legend Location in Graph Builder
Hi @faraz,
Absolutely. You will find those options under the Red Triangle next to Graph Builder at the top left > Legend Position:
@julian
julian
Hi @faraz,
@julian
kweng
Hi Julian,
My question is not related to the Legend location. I saw your plot with selected histogram plot but showing "distribution" graph on the graph builder. I try to do the same plot to display "distribution" instead of "histogram bin" but can not figure out how to do this. Would you provide some information how to do this?
thanks
Ken
julian
Hi @kweng,
It's a neat display of data, isn't it? These kernel density histograms were added to Graph Builder in JMP 15. Once you are showing the Histogram element, toggle "Kernel Density" as the Histogram Style in the control panel on the left.
Here's a short video showing all the steps to make that graph using the Big Class sample data table.
GB-Dist.mp4
Video Player is loading.
Current Time 0:00
Duration 0:23
Loaded: 0%
Stream Type LIVE
Remaining Time 0:23
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    I hope this helps!
    @julian
    kweng
    Wow, that's very nice. Thanks bunch Julian!.
    I think I need to upgrade my JMP 14 to JMP 15.
    -Ken
    Rajat
    @julian, Is there a way change the default position of legend?
    julian
    Hi @Rajat,
    Absolutely! The place to find all the platform preferences is by going to File > Preferences. Next, select the Platforms group on the left, then select Graph Builder. Finally,check the box to specify the location for the legend by default. If you find that you're changing something in a platform regularly it's worth setting a preference for it.
    I hope this helps!
    @julian
    Rajat
    Thanks @julian
