BookmarkSubscribeRSS Feed
ana_v
Oct 6, 2015
Change multiple data table names product of a subset
I would like to change in batch the name of multiple opened tables which are a product of a Table subset.
If I use the following script to subset a table named "MyData.jmp", I get tables with the name of the original table followed by a space and a sequential number (e.g. "MyData 1", "MyData 2", "MyData 3" , "MyData n"). Instead I would like to give each table the name of the specific level of the column by which it has been subset (as explained after the script).
//Subset a Data Table (By different column levels).
Data Table( "MyData.jmp" ) <<
Subset(
    By( :Ref ),
    All rows,
    Selected columns only( 0 ),
    columns(
        :day,
        :month,
        :grid,
        :Ref
On the other hand, it if I subset the table ("MyData.jmp") using the interface I get table names such as "Ref=P100_1", "Ref=P100_2", "Ref=P100_25". Meaning that I have subset the table by the column "Ref" and after the "=" the levels of the column that by which I have subset appear. In this case I am interested in having just the part "P100_1", "P100_2", "P100_25" as the names of the tables. In this case I would need to delete in batch the same text from all of the data tables ("Ref=").
ian_jmp
Jun 23, 2011
Re: Change multiple data table names product of a subset
Here's one way:
// Eaxample table
// Example column
col = Column(dt, "age");
// Make subsets by :age
colLevs = AssociativeArray(col) << getKeys;
For (i=1, i<=NItems(colLevs), i++,
r2get = dt << getRowsWhere(:age == colLevs[i]);
dtSub = dt << Subset(Rows(r2get));
dtSub << setName(Char(colLevs[i]));
ana_v
Oct 6, 2015
Thanks Ian@JMP!
The script worked very nicely indeed.
I introduced the "invisible" factor to the sub tables to avoid having many windows open and then save them as a text file (with another script). It seems to have worked also fine.
// Eaxample table
// Example column
  dtSub = dt << Subset("Invisible", Rows(r2get));
