hogi
Level XIII
Caution: Places where Jmp does something unexpected
Definitely, JMP is Not a Spreadsheet . And that's great!!
Besides this difference, there are other places where Jmp doesn't do/behave/produce what a newbie / innocent Jmp user expects.
If a user knows these issues and the remedies and workarounds -  he/she can
a) save a lot of time
b) be safe from data loss
c) be sure that the results are as expected.
[More Topic Containers like this]
Topic description Links
There are several steps where CTRL-Z (Undo) doesn't work
Where Ctrl+Z / Undo will help
Data Tables
Formula column + excluded rows
Unlike plots and reports, column formulas  don't use the information about  excluded rows. Workaround:
col mean(:height, excluded())
Formula Editor: meaningful results with excluded rows
Compute Column Mean ...Col Max() ... excluded row
Col Functions and Row States
Exclude data in formula
Source Scripts + Tables/Update Tables/Update overwrites an existing Source script
same issue for Concatenate + Append to first table
Update & Concatenate:source script collision
workaround,
@internal:
use our bug-fixed Update platform
it archives the source script before overwriting it
Danger!
Besides importing new data from an Excel file,
the script resets ALL changes of the data table. (!!!)
Disable "Update Table" script?
issues with dates JMP prefers M.D.Y
this can lead to issues with D.M.Y
 CSV import force MDY or DMY date format
issues with decimal separator file import: no setting for decimal separator
neither via GUI nor via JSL
txt import - point and comma ?
 Make decimal separator an option
Score unique & count unique
 excluded rows are excluded from the calculation.
values don't get updated after changing the row states
 score Unique & count unique
Platforms
Query Builder + Formula Columns Formula Columns get transferred to the result table, where they get evaluated again. Issues with dif(), Lag(), Col.. () aggregations ... !
Why is there such unexpected re-calculation of columns without formulas?
issue with excluded() Some of the Platforms of the Tables menu
produce their output ignoring the excluded() row state, others take the excluded() row state into account.
Handling Hidden / Excluded rows / columns in Table-handling
Tables/Split
possible issue with Keep
Split merges multiple rows into a single row. "Keep" - which entry? the first one - can lead to surprising results:
Bad Stacking?
Scoring in Graph Builder The graph doesn't get updated when row states are changed in the data table
JSL
Jmp doesn't wait till a data table is fully processed when executing subsequent JSL code. add wait()
or dt << run formulas()
 When to use Wait(0)?
Why is there an empty table if you don't add wait()?
run table script
Python
Graph Builder
Platforms in JMP accept fractional values as Freq : ) ... Graph Builder doesn't
Freq and Weight: better documentation
Graph Builder
+ Heatmaps
there should be an option to disable the
automatic adjustment of the axis increment
Heatmap - option: fixed Tick spacing (aggregation area)
Graph Builder
+ manually changed axis labels
Manual axis labels are mixed up when columns are added, removed or dragged to a different position Manual axis labels are 'mixed up' when plotting multiple columns
Bug fixed  in JMP19
Type Properties Type properties collide with Data Filters
-> significant harm for exploratory data analysis
https://community.jmp.com/t5/Discussions/consistent-marker-and-style-control-type-properties/m-p/917...
Several Inconsistencies of Color/Style settings in Graph Builder   Why is this DropZone called "Color"
0 REPLIES 0
