johanna_younous
Make invisible data table out of a graph builder
Hello ,
Inside a loop, I make datatables out of graph builders . Point is that I would like those data tables to be invisible and I cannot figure out how to do it. As an illustration, here is the exemple from the scripting help :
obj = Graph Builder(
	Variables( X( :Sex ), Y( :Height ), Group X( :Age ) ),
	Elements( Box Plot( X, Y ) )
obj << Make into Data Table(invisible);
 I tried also
dt = obj << Make into data table <<invisible;
dt = obj << Make into data table;dt <<invisible ;
dt = obj << Make into data table(visibility ("invisible")) ;
and some other combinations  but nothing is hiding the data table and I cannot figure out what is going on.
I'm working on JMP 14.1.0 (64 bits)
Thanks a lot for any help !
regards
Re: Make invisible data table out of a graph builder
I think usually the syntax is Invisible(1). If it doesn't work, you can turn the window invisible after it has been created
obj = Graph Builder(Variables(X(:Sex), Y(:Height), Group X(:Age)), Elements(Box Plot(X, Y)));
dt = obj << Make into Data Table(); // usually syntax is invisible(1)
dt << Show Window(0);
wait(0); // might not be necessary
johanna_younous
Thx, it works!
Still I wonder why the usual "invisible" spécification while making the data table is not working here..
Anyway, I have solution ! Thank you again.
