Marco1
Can JMP show the probability of 1 result or range through a graph?
Hello everyone!!!, a question:
What graph in JMP can answer the probabilities of obtaining a value or range of response, for example like the following graph.
Greetings,
Marco
57 REPLIES 57
hogi
Level XIII
Re: Can JMP show the probability of 1 result or range through a graph?
  1. sure - just "unlock" the number edit boxes and slightly adjust the script
  2. ?
  3. sure, just include it in an add-in (as I did for the video)
Marco1
How do I include it in a plugin?
hogi
Level XIII
Either via New/AddIn (see Jmp ducumentation)
or via Add-In Manager
A bit more effort to set it up - but then a real pleasure for the rest of your work life.
Marco1
Ok, regarding the graph, you would need to allow entering the minimum and maximum value, is that possible?
hogi
Level XIII
Yes, as I mentioned before, you just have to disable the lock.
Or you use the approach via he data filter, which I showed in one of the first replies:
https://community.jmp.com/t5/Discussions/Can-JMP-show-the-probability-of-1-result-or-range-through-a...
Marco1
Hello JTHI,
Excellent approximation!!!, it is almost the same as the example I shared...that is, now in the graph you can place the minimum and maximum numbers (ranges) and it shows the probability of certainty......two queries:
1. Could the script accept more than 1 objective?
2. Can it be an add-in for JMP?
Greetings,
Marco
What do you mean by more than 1 objective? Do you mean, that you would like to "save" the selected ranges? Or that you would like to have more than one column?
Marco1
More than 1 column.
And how should they be displayed? In same graph (how would it behave if values are totally different), different graphs (should they be on same page visible at the same time) or should user be able to switch them as needed (so basically only one visible at the same time, but easy to change between them)?
Marco1
A column chart, like JMP does in bar charts, for example:
