rich_greves
Can JMP put the sample number on box plots
I have a simple graph that gives me a series of box plots that that show the concentration of a pollutant by month.  Is there any way to have JMP attach the number of samples that  were analyzed to create each box7243_Clipboard01.jpg
XanGregg
Re: Can JMP put the sample number on box plots
A couple possibilities:
You can put the X variable in Group X and turn on the Caption element, choosing N as the caption statistic:
Or you could make an computed character variable that represents the count and nest it inside of the X variable:
And in case it doesn't go without saying: you can always manually add text annotations or a custom graphics script if you need maximum flexibility.
XanGregg
