lala
Level IX
Can JMP draw this pattern?
Hello!
Draw a horizontal bar chart of height data,
Graph the data on weight.
Superimpose two graphs on one graph.
2022-06-10_22-34-34.png2022-06-10_22-34-34.png2022-06-10_22-12-58.png2022-06-10_22-12-58.png
Re: Can JMP draw this pattern?
Here is my attempt.  It creates the needle chart transforming the Height and R values to match the range of the Weight and .25% of the r axis.  The a FrameBox copy is done from one graph to the other;
names default to here(1);
// Open Data Table: big class.jmp
// → Data Table( "big class" )
dt << new column("r", set each value(Row()));
gb1 = dt << Graph Builder(invisible,
	Size( 528, 454 ),
	Variables(
		X( Transform Column( "r 2", Formula( :r * 0.25 ) ) ),
		Y(
			Transform Column(
				"height 2",
				Formula(
					If( Row() == 1,
						ytargetmax = Col Max( :weight );
						ytargetmin = Col Min( :weight );
						ytargetp = (ytargetmax - ytargetmin) / 100;
						ymax = Col Max( :height );
						ymin = Col Min( :height );
						yrange = ymax - ymin;
					yp = ((:height - ymin) / yrange) * 100;
					ytargetmin + ytargetp * yp;
	Elements(
		Bar( X, Y, Legend( 5 ), Bar Style( "Needle" ), Response Axis( "X" ) )
gb2 = dt << Graph Builder(
	Size( 528, 454 ),
	Variables( X( :r ), Y( :weight ) ),
	Elements( Line( X, Y, Legend( 5 ) ) ),
		Dispatch(
			"weight",
			ScaleBox,
			{Min( 60.8877083333333 ), Max( 178.48 ), Inc( 20 ), Minor Ticks( 0 )}
report(gb1)[framebox(1)]<<copy frame contents;
report(gb2)[framebox(1)]<< paste frame contents;
gb1<<close window;
Yes.  Graph Builder can easily do this.
  1. I added a transform column set to the Row() and used it for the X axis
  2. I dragged Height and weight to the Y axis
  3. Moved Weight to the right side axis
  4. Then I went into the axis settings for each axis and removed all tick marks and labels.
Documentation on Graph Builder is in the Essential Graphing document
18 REPLIES 18
I'm not exactly sure what type of graph you want to plot. You have two different Y-axis on same axis and x-axis which scales to some other values for other data.
You can for example plot something like this where you move other X-axis to other side:
lala
Level IX
Thank Jarmo!
That's exactly what I want.I want the red graph to be shorter on the X-axis.
Hope to get specific aspects, Thanks!
This kind of graph is easy to draw with Excel, and two data are made into different graphs respectively.Then set the background of one to transparent and overlay it on top of the other.
lala
Level IX
excel
ih
Super User (Alumni) ih
I know this isn't exactly what you asked for before but I frequently draw graphs similar to this, maybe this recording will give you some ideas on how to make something like what you are looking for:
(view in My Videos)
lala
Level IX
Thank you very much!
I learned this method through videos and saw how adding rows can be done this way.
lala
Level IX
	Size( 528, 454 ),
	Variables(
		Y(
			Transform Column(
				"height 2",
				Formula(
					If( Row() == 1,
	Elements(
	Size( 528, 454 ),
		Dispatch(
			"weight",
			ScaleBox,
gb1<<close window;
lala
Level IX
Thank Jim!
This is exactly what I want.How do I change the color of GB1 (bar chart) to red?I still haven't learned.
The lines are combined with the line chart, which means whatever the line color is, the needles will be the same.
