This website uses Cookies. Click Accept to agree to our website's cookie use as described in our Privacy Policy. Click Preferences to customize your cookie settings.
I am having trouble in a data set getting the best line of fit. I am able to get the smooth line in graph builder but when I click "best fit" icon nothing happens. Then when I run fit Y by X, I don't see anywhere I can select the best fitting line. Do I need to change something in my settings maybe?
Your time variable has the nominal modeling type. That means JMP thinks it is categorical, therefore regression (or best fit line) is not appropriate. Change the time to have the continuous modeling type.
Here is a picture of the example. As you can see in the picture I have both the smooth line and the best line of fit selected, however, I only see the smooth line.
Dan Obermiller
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '229369' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if (newSub.getAttribute("slang").toLowerCase() == code_l.toLowerCase()) {
if (value == '229369') {
else{
} else {
sub_L = newSub.innerHTML;
try{
catch(e){
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
